Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
01-19-2007 10:40 AM
01-19-2007 11:19 AM
Try the following: Got to "VI properties...execution". Now place a checkmark for "Clear indicators when called". That might be enough. 🙂
(If you are looking for a programmatic solution create an invoke node in the first or last frame as desired, wire it to a reference to the current VI and select method "renintialize all to defaults".)
01-19-2007 12:31 PM
01-19-2007 01:52 PM
01-19-2007 02:21 PM
Yep, that was the bomb. My application looks and operates almost perfectly! Thanks for the excellent advice!
Rick Horwitz
