How Covert Cluster to Dynamic data
Hi!
How convert output cluster to dynamic data in order to filter my signal before graphing?
(2,036 Views)
Hi Alo,
Why do you want to bundle at all?
What do you expect from a cluster of two arrays for your filtering function?
Why do you rely on DDT wires? (They are considered "bad"…)
Why don't you filter your I and U signals (before bundling the filtered data for that graph)?
(1,997 Views)
I am trying to filter, using smoothing, the output that the cluster has before entering the graph, without filtering it is very noisy, but I don't know how to fix that part anymore
The data that vi gives me is so noisy, and I want to smooth the graphs from labview without having to use any software like origin
Even smoothed with origin, the graphs have noise at the beginning and at the end of the data collection, in this collection I am using a cryo9012 and the fet method for current and voltage characteristic curves
(1,973 Views)
Use the Digital IIR Filter VI.  You will need to use Build Waveform to convert your float array into a waveform data type.
(1,958 Views)
