How Can I Lock Control/Indicator/Graph Markers?
Is there a way to lock the position and value of the markers so that they cannot be modified while the VI is running?
I'm trying to make my VI as idiot-proof as possible so that a user won't ruin the front panel. Any input is appreciated.
Jeremiah
(3,742 Views)
Hello Jeremiah.
Can you arrange to simply disable each control the user is not allowed to modify? That should be the easiest way.
(3,731 Views)
I still want the user to be able to use the control, just not modify the marker labels or the marker placement.
(3,726 Views)
I may be mistaken but I think the Allow drag property for cursors will do it. Waweform graph propety node>>Cursor>>AllowDrag
Cyril Bouton
Active LabVIEW Developper
(3,723 Views)
Ignore my post,
I made a mistake between cursors and markers...Sorry.
Cyril Bouton
(3,718 Views)
There has been a discussion a few time ago on the same subject. See :
http://forums.ni.com/ni/board/message?board.id=170&message.id=100975#M100975
CC
Chilly Charly    (aka CC)
(3,707 Views)
I think I've found a workable solution. By converting the numeric marker values to text values, the user is no longer able to change the markers while the VI is running. This works well for controls, not too sure if it can be applied to indicators or graphs. Thanks for all the input.
Jeremiah
(3,677 Views)
