How Can I Get NI Vision 8.5 to Work With LabVIEW 8.60?
Hi guys,
I haven't install LabVIEW 8.6. Most of my modules the version is 8.5 or 8.5.1. How can I get NI vision 8.5(not SSP)
to work with LabVIEW 8.6? And so on. Thank you!
B/R
Ancle
(2,878 Views)
Hi Ancle,
normally you should first install LabVIEW 8.6 and then Vision again. Then you should be able to work with it.
Hope it helps.
Mike
(2,861 Views)
Hello Mike,
Thanks for reply. I used the below method, copy from LabVIEW 8.5 to LabVIEW 8.6. It works fine.
http://digital.ni.com/public.nsf/websearch/3DA1116F94211ED0862571D3005CBF3E
(2,823 Views)
