How Best to Draw Path for User Data to Follow? [2D picture controls? XY graph? other?]
Hi all,
I am a PhD candidate and I have looked all over the forum and interwebs for someone who is doing something similar to no avail.
My task (which I've found common in academic research) is displaying a path for a user to follow with some user-generated data.
I've attached a picture of my research setup just for fun (helps visualize the task).
I want to display to the person a path for them to follow and the pedal crank arm positions will correspond to X and Y of the user cursor.
The method I started trying was using a 2D picture control to display a path and then a 2nd 2D picture control overlaid with the user cursor data (picture refreshed every iteration). I've attached a sample vi to give you the basic idea of where my head is at.
My main question is: is this the best method for what I'm trying to accomplish? I assume that this is pretty common, but I could not find a similar example. Perhaps doing this with an XY graph? Or maybe just using only 1 picture control and re-drawing the path every iteration as well as the new cursor position?
FYI the code I posted is with LV 2020 Community Edition, but the edition of LV on the PC which controls my motors is LV 2015 SP1 - if that is relevant for any suggestions.
Your help is greatly appreciated,
tom
(1,609 Views)
You're making things more complicated than necessary.
See attachment.
(1,581 Views)
Paul,
Thank you for the edits - I've learned a good deal in just the few changes you made. For some reason I didn't think to use the Event Structure in this use case.
As to my overall paradigm though, you would agree that overlaying two different 2D picture controls is a good way to go about this? I'm new to creating visual feedback scenes with LabVIEW so I want to make sure I'm using a solid methodology.
tom
(1,551 Views)
Accepted by topic author tsr26
@tsr26 wrote:
Paul,
tom
Seems OK.
Another possible way is to just move an object around the front panel instead of re-drawing a picture.
The downside to that is that it complicates the handling of coordinates,
(1,512 Views)
