Hot to 'scroll' through FFT
Hi
I am reading a binary file into LV which I contains pressure values gathered from a microphone. The data is then built into a waveform and passed to the SVT scaling Vi. From there the data is passed to a sound level vi and into a graph.
What I would now like to do is create a vi to open the data, and then display an FFT that can be moved around to give the frequency spectrum at any point in time during the recording. Any ideas how I could do this?
Cheers
Dave
(2,508 Views)
Does the attached 'sample' get you somewhat nearer the solution.
There is no doubt that the sample needs to be 'adjusted' to suit your needs.
(Posted in Labview 7.1)
(2,498 Views)
