Hot key for run time menu
I want a hotkey (preferbly the ENTER button) to initiate a menu. That is when I press ENTER, the FILE menu gets highlighted with all the pull down options are displayed. Please give me a solution.
(2,828 Views)
Hi rberger,
There is no simple setting that will allow you to dedicate the ENTER button to open the menu. However, with a little bit of magic (Event Structure looking for ENTER key press), you can programmatically (using the "keybd_event" function in "User32.dll") click the ALT (Menu) key and then the ENTER key. This combination will always open the menu list (try it manually first; ALT and then ENTER).
Try the attached VI that I created for you.
Have fun!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,806 Views)
Thanks for your reply. However, there is a subVI missing in your file attachment.
(2,797 Views)
Ooops - sorry rberger!
Here's the VI including the very necessary subVI. Let me know if you can use it, thanks.
Have fun!
Thinkbot Solutions
(2,782 Views)
