Host realtime server program on DAQ-PC or on Server
As the attached diagram, we have existing system, now need to upgrade with realtime data polling function.
Should I use solution 1 or 2. Any suggestion, thanks.
(2,341 Views)
According to me you should follow the step 1
1. Real Time Server is directly connected with your Client application no database Server Required.
2. Database server you can use only in the condition of generating the Historical Trend or various reports.
3. Database server work independently to store your acquire the data.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,334 Views)
