Hole Filling, Image Correlation & Contour Detection on RT
I am want to implement Hole filling, Image Correlation & contour Detection on Real Time controller. VI's are available to perform them but I am not able to find the examples for these VI's.
So is it possible to perform these algorithm on Real Time? I am having the NI RT PXI controller
(3,222 Views)
If you can't find the examples in the example finder you can always try to go through the help.
If you drop an IMAQ FillHole VI on the BD and select Detailed help in the contect help, the help topic has an example listet, which is located in your LabVIEW installation directory. (LabVIEW\examples\Vision\2. Functions\Binary Analysis\Particle Analysis Example.vi)
Remember Cunningham's Law
(3,202 Views)
