Hoe I can convert a word or sentence into audio output using LabVIEW like the windows narrator?
I am converting Braille script to audio output using LabVIEW. So, I need to convert the script to english and then to audio. How can I do it?
Subash Sainath Gururaj
(3,961 Views)
From what I've seen in my brief search, you need to go the ActiveX route.
Bill
CLD
(Mid-Level minion.)
(3,899 Views)
And I'm guessing that Braille is just a font?
Bill
CLD
(Mid-Level minion.)
(3,893 Views)
Does it have to be Windows?
On OSX, you just run an AppleScipt (from LabVIEW) and use the SAY command (Say "The temperature is 73 degrees").
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,866 Views)
