Historical Trend
I am using Historical Trend and it gives me the possibility to view just one shared variabe.
However I need to view more than one shared variable at once.
please how can i view more than one variable (3 variables for example) at the same time in the Historical trend ?
could you help me ?
Samer,
Message 1 of 13
(5,168 Views)
If you re using the Historical Trend Express VI from the DSC palette, see the attached pic to get an idea of how to do it. Smiley Happy
Now, your XY Graph will show the shared variables you have configured.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 13
(5,164 Views)
Hi Partha,
i forget to specify that i need to do that by controls using the input "shared variable list" of Historical Trend.
How can i input more than 2 variables ?
could u help me ?
Samer,
Message 3 of 13
(5,158 Views)
Use an array for the Shared Variables input.
Message 4 of 13
(5,145 Views)
I have tried but the Graph XY shows just the graph that corresponds to the first element of the array.
The URL of the second and third element of the array have no influence on the Graph XY.
Could you tell me why ?
Samer,
Samer,
Message 5 of 13
(5,128 Views)
We can tell you why, if you post your code here. Smiley Wink
Message 6 of 13
(5,103 Views)
Hi, here is the VI Smiley Wink
Samer,
Message 7 of 13
(5,094 Views)
and here is the image that shows the Graph XY...
Thx
Samer,
Message 8 of 13
(5,084 Views)
What happens if you run each variable by itself for the same time ranges?? Do you get different sets of data for each graph? Is there a reason why you have autoscale Y axis turned off?? It could be hiding some of the data of the chart.
Message 9 of 13
(5,065 Views)
- when i run just one variable by itself i have a graph each time
- yes i have different set of data for each graph
- i turned off the autoscale Y...the result is the same
Then i still have the 2 problems:
- the graph is still showing me one variable for severable inputs
- the graph doesn't put lines between the acquisition points
Could u help me ?
Samer,
Message 10 of 13
(5,029 Views)
