Historical Data Display
I find 100 peaks per second from continuously acquired data and would like to display a histogram of these peaks for atleast 30 min. That would be 180000 data points.
At the moment i can only think of a Waveform chart with chart history length set to desired data points. Are these too many data points, performance wise?
What are my other options?
Message 1 of 9
(5,634 Views)
Hi zezenda,
why would you use a chart just to store some data? (A chart is an indicator, meant to present data to a user!)
Why not use a shift register holding an array of your values? (You could even predefine this array in size as you seem to know sample rate and measurement time in advance!)
Message 2 of 9
(5,613 Views)
Thanks you Gerd. I would also like to display all these peaks of last 30 min, thats why thought of a chart.
Message 3 of 9
(5,607 Views)
Hi zezenda,
you surely talk about "samples", not "peaks"! (To show "peaks" you would need a lot more "samples"…)
It doesn't make sense to show 180k samples in a ~500pixel wide display: each pixel would represent 360 samples. It would make more sense to decimate the data for display and to show only "extraordinary" events…
Message 4 of 9
(5,598 Views)
Sorry i am not clear enough. I do want to show only peaks. I am acquiring at a much higher sampling rate, detecting peaks of interest and would like to display them in a histogram for 30 min, to get an idea of how peak amplitude and/or frequency changes over time.
Message 5 of 9
(5,595 Views)
Check out my article: Monster Panel, Part V
Especially if you have multiple channels, you do NOT want to use a chart.
The article explains how to use a graph to:
--- switch channels and get prior history for the new channel.
--- get variable-length history.
--- update the graph properly as data comes in.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 6 of 9
(5,574 Views)
I am generating an array of defined size and creating a histogram of the values. Now the histogram shows values from each loop iteration. I would like to have data from all the iterations appended continuously in a kind of waveform chart for a certain amount of time.
Message 7 of 9
(5,567 Views)
Hi zezenda,
why are you doing this all that complicated? (And why did you start a new thread?)
I replaced your generic histogram with its Pt-By-Pt counterpart…
Edit: I forgot to set a reasonable "sample size" for this function!
Message 8 of 9
(5,557 Views)
Thank you for this but how do i display a dynamic histogram which is updated continuosly for 30 min?
Message 9 of 9
(5,548 Views)
