Histogram
For time analysis of my data I use the Histogram vi from Signal Express-Signal Analysis-Time domain measurements, input 1 channel (scalar U32), 2048 bins. The output of this histogram vi is a cluster that can be represented in a graph as counts (bins) versus time. Can anybody inform me about the data structure of the cluster? After regrouping the bins into a new (reduced) representation I have to bundle the regrouped data into a new cluster, but I do not know what I have to input into the elements of the bundle vi.
Message 1 of 13
(5,502 Views)
If you have a question about your code, it always helps to post your code.  Do attach a VI.  Do not attach a picture (unless it is a LabVIEW Snippet) of your VI.
Message 2 of 13
(5,469 Views)
The data structures that each type of chart or graph supports is in the help documentation. What kind of graph are you wanting to use? (An XY is often easiest and supports several different data structures)
What are you doing to the data coming from the histogram?
In short, Code! We need to see some Code!
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 13
(5,461 Views)
"Do not attach a picture (unless it is a LabVIEW Snippet) of your VI."
Or kitties, Bob likes kitties... 🐈 😇
LabVIEW Champion
Message 4 of 13
(5,455 Views)
I like cats, but not pictures of cats ...
BS
Message 5 of 13
(5,439 Views)
Snippet of preliminary vi
Message 6 of 13
(5,390 Views)
The term "Snippet" has a specific meaning in LabVIEW.  Open LabVIEW, click on Help, LabVIEW Help, search for VI Snippet.  Follow the clear directions, create the .PNG that LabVIEW (not the Clipboard, not Windows, not Word) creates of your code.  That is what we mean by a "LabVIEW Snippet" -- it is both Picture and code, and it is the code that we need.
Remember, you are asking for our help, so you (should) want to make it as easy as possible for us to examine and test out your code.  That means, you provide the code in some fashion -- you don't make us open LabVIEW, look at your code, switch to the Block diagram, try to lay down the functions and wires exactly has you have done (making possibly the same mistakes, like running a wire underneath a function without connecting it).
Provide us with your code.  I apologize for not simply saying not a picture (and then giving the exception, which confused you ...).  Providing the entire VI is the best, as sometimes (particularly if there is a problem with the code) the culprit is not the 3 or 4 functions that "seem obvious", but the way that the wires come into the structure that we can't see if you only show a small piece of code.
Message 7 of 13
(5,379 Views)
May be this can be helpfull ?
Message 8 of 13
(5,340 Views)
What is this code supposed to be doing?
Mike...
LabVIEW Champion
Message 9 of 13
(5,318 Views)
No, it is not particularly helpful, as we know nothing about the inputs.  Consider attaching the entire VI, itself, and not a Snippet.  Maybe we can figure out what you are trying to do ...
BS
Message 10 of 13
(5,284 Views)
