Histerisis condition
Hi everyone,
I've one sensor and one reference value. I want to change a boolean value when de diference above is more than 0.5. Then, I want to keep in that state until the variable value is 0.5 lower than the reference one. How could it be done? I attach a capture where there is a code which only does one part.
Thank you!
(1,870 Views)
Hi George,
Use a shift register in your loop to store the current state of the boolean. Then use a case structure to handle your two cases to check for the next "change condition"…
No, you did not attach anything…
(1,846 Views)
Accepted by topic author George7893
I finally solve it as the capture attached by using another post. Thank you anyway.
(1,844 Views)
Hi George,
why do you need DDT wires and so many functions?
See this as suggestion:
(1,840 Views)
Hi again!,
Of course your model is really simple but I'm not able to make it work in my VI. I attach the whole graphic. I'm new in LabView, so maybe I'm confused with something.
Best Regards
(1,827 Views)
Hi George,
don't use express VIs and their DDT wires: they will not help you in the long run!
As a quick fix: place a FromDDT function after the filter express and convert to scalar DBL.
(1,774 Views)
