Highlight cell in array of clusters
i have question about array of clusters. I want to do some list of commands where i use table of arrays. In array are 2 tables one string and one image controller. I found code that find me active (clicked cell in this array but is there any way how to highlight this cell? I tried to changed background color of this cluster but this change color for whole table. Can you help me. My program is attached.
(3,346 Views)
in an array all elements share the same properties - with only one exception: their value! Point. No way around.
You have to use something different then this property. Maybe you could put an array of colorboxes behind your (transparent) table to mimic the highlighting by setting the colors...
(3,343 Views)
Add a color box to the cluster; put it behind the object to want to highlight, and make sure that object has a transparent background.
(3,332 Views)
Ok guys i will try this
(3,317 Views)
(3,302 Views)
