Highest element from multiple arrays
I have four 1D arrays (each about 80 elements long) stored in slightly different places in a 'super-cluster' (the most relevant levels can be seen in the picture below). I need to find the value of the highest element in these arrays. I've come up with a couple of methods but it's getting late in the day and they all seem depressingly convoluted. What's the best/fastest way to do this? In a comparable example, I will also need to find the lowest element of four different arrays.
Never say "Oops." Always say "Ah, interesting!"
(3,620 Views)
Accepted by topic author J.Mamakos
Use the Array Max &Min function
(3,612 Views)
I did consider that, but then convinced myself that creating a higher-level array just to find my answer was going a bit over the top! Or does it not really matter in this case?
(3,608 Views)
I'd say, in this case, the simpler the better.  Just use Build Array and use the Array Max & Min.  The other solution I would consider would be to use the Array Max & Min on each of the arrays, and then build an array of the maxes and use the Array Max & Min again.   But this sounds convoluted and probably a lot slower than just building a big array.
(3,600 Views)
Since it's 4 arrays of 80 elements it won't cause any memory issue. If you had 4 huge arrays then it would be preferable to find each array max and then compare them.
Ben64
(3,594 Views)
Okay, thank you. You can probably tell I didn't have a relaxing weekend! (so tired) Smiley Very Happy
(3,592 Views)
