High speed data aquisition
hi
        I am using cRIO 9004 RT, 9104 FPGA and 9215 I/O module(100KS/s) for high speed data aquisition. But i am unable to obtain 100KS/s properly using the attached VI. please give me possible solutions.
Thanxs in advance
Sooraj
(2,577 Views)
Hello Sooraj!
I would recommend you to make use of DMA in order to achieve the transfer speeds you are requesting. The method you have chosen with synchronous display will not work well here.
Hope this helps!
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,556 Views)
