01-05-2012 03:22 AM
Hi
This is my first time to use CAN.
I have LabVIEW 2010 and LabVIEW FPGA
01-06-2012 12:13 PM
The way that you have proposed to use the CAN module to monitor the BUS is a bad idea. We have a prebuilt driver that will do most of this work for you. You will need to download and install the NI-CAN 2.7.3 and then you will be able to use the example finder. In the example finder look for.
The example finder is accessed through the Help menu.
