High Speed Data Logger
Hello Ni,
                 i am looking to do some high speed data logger using labview. customers expects high speed data logging and it should be 10K sampling rate. ofcourse we can acquire the data in 10KS/s and store using TDM file format. thing is that how can i retrieve and analysis the data.... but it should be done by labview environment i mean same IDE.
need some suggesstions..
Balaji DP
(3,091 Views)
What are the signals you are recording and how many channels do you need as 10KS/s isn't difficult but don't go datalogging for hours at a time otherwise you will create huge files, take some time to consider how you want to trigger the recording and the duration. Without knowing what the signals are from its difficult to suggest a replay display but there are loads of different options available - Mike
(3,076 Views)
