High Resolution Polling Wait protected by password
I have an issue with the High Resolution Polling Wait that may be resolved by doing this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019c9TCAQ&l=es-CL
In order to do that, I need to go to the block diagram window, but the VI is protected by password. I have no idea what the password could be, and I'm stuck there.
Any ideas?
Message 1 of 10
(3,175 Views)
It's not PW protected on my system.  What LV version are you using?
Message 2 of 10
(3,168 Views)
Hi, Paul,
I run NI LabVIEW 2020 SP1 64 bits.
(Thanks for the laugh, by the way)
Message 3 of 10
(3,155 Views)
Same here. I can confirm that the diagram has a password. (might be an accidental oversight).
Message 4 of 10
(3,149 Views)
It is not password protected on LV 2019 64-bit windows10.
Are you using LV on Mac?
Santhosh
Soliton Technologies
Message 5 of 10
(3,136 Views)
No, Windows 10
Message 6 of 10
(3,133 Views)
Accepted by topic author MatiMarin
Sorry y'all, that was me. We added the VI in LabVIEW 2018, where it had no password. Then, in LabVIEW 2020, it got password-protected by an automated process (run by me) because it calls some internal LabVIEW callbacks on Mac (as described somewhat in the KB entry linked above).
I've attached a non-password-protected copy to this reply, saved in LabVIEW 2020. You should be able to drop this in your vi.lib/Utility folder in LabVIEW 2020 or 2021 (backup the original first, just in case). I have filed Bug 1733037 to LabVIEW R&D to remove the password in a future LabVIEW release.
Message 7 of 10
(3,100 Views)
Hi Darren,
Thank you for your help, it was really kind of you.
Matías
Message 8 of 10
(2,986 Views)
Ni LabVIEW vi password protection becomes a joke. There are programs that open any password protected vi in less than 100ms
Message 9 of 10
(1,670 Views)
https://github.com/tomsoftware/VI-Explorer-VI
Message 10 of 10
(1,649 Views)
