High CPU load after resuming from sleep mode
When my laptop resumes from sleep mode, LabVIEW 2012 starts to generate a very high and always constant CPU load (25%) without any VI running. I need to close all front panels to get back to the usual <1% CPU load level.
This behaviour spoils my carbon footprint and frequently eats up my battery. Any ideas what is causing this ?
Thank you,
Dirk
(2,757 Views)
I'm guessing your issue may be related to this:
http://forums.ni.com/t5/LabVIEW/Why-is-using-100-of-a-CPU-1-out-of-8-when-it-does-nothing/m-p/242745...
Thank you,
Dirk
Sorry about your carbon footprint, NI has a lot to answer!
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,750 Views)
Thank you, .aCe. , those threads seem to be relating to the same issue.
When will we finally see a truly semantic, not keyword-based search engine that makes it easier to find similar threads? 😉
D.
(2,743 Views)
