Hierarchy showing XControl properties
How do I make custom properties for an XControl show up in a hierarchichal manner when the user is selecting the property when configuring a property node.  For example, to set the label text property for a boolean control, a user right clicks a property node for the control, selects "label", and then "text".
(2,766 Views)
(2,762 Views)
You might also look at the LabVIEW help to do this.  If you search for "xcontrol" and then look for creating properties the topic is covered. I hope this helps but post again if the process is still unclear.
Eric A.
Distributed I/O Product Support Engineer
(2,732 Views)
