Hide indicators
Hi everyone
I have two subvis:subvi1 and subvi2
Subvi1 contain a listbox with three values which the operator will choose one of them.
Subvi2 contain a number of indicators, and depending of the chosen value some of them must be hidden.
I tried to use property node but I didn't found a solution.
Any suggestions??
(2,802 Views)
Accepted by topic author Rafa06
Did you use the Visible Property Node?  That is the solution.
If you still have problems, then post your VI so we can see what you are trying to do.
(2,800 Views)
