Hide/Show a single control in cluster
HI all...
I'm trying to do something but with no luck...
I have 2 clusters of 20 controls each,
1. 20 Boolean switches
2. 20 numeric indicators ( dbl )
What I want to do is simple when I'm pressing one of the bool buttons I want it to hide/show the relevant numeric.
Can anyone assist ?
Kobi Kalif
Software Engineer
(4,575 Views)
Hi kobi,
             You can refer to the following links:-
             http://forums.ni.com/t5/LabVIEW/Show-Hide-certain-items-in-an-array-of-clusters/td-p/1672798
             http://forums.ni.com/t5/LabVIEW/how-to-disable-numeric-controls-in-a-cluster-one-by-one/td-p/90303
Thanks as kudos only:)
(4,565 Views)
Hello Kobi Kalif,
please have a look at the attached example.
Greets, Dave
(4,564 Views)
Accepted by topic author Kobi_K
Its a bit quick and dirty but does this do what you want.  Use numeric control to select element in cluster and boolean to turn on or off then press run.  Could have put it in a loop with stop button
Ken
(4,563 Views)
Thank you all all the ideas where very helpfull !!!
Kobi Kalif
Software Engineer
(4,553 Views)
