Hi
I need to output 6 non-repeating patterns to 3 PCI-6111's @ 150kHz.
Can anyone explain to me why the attached LV7 Development Library example, with modified defaults and utilizing DAQ occurrences, will not work when more than one copy is run? When I try to run a second copy (with the device number different) the first copy produces a -10803 error.
Another example (also attached) will successfully allow 3 copies to run simultaneously. While it can get the job done, I was wanting to use the DAQ occurences, because I thought that would allow the minimum amount of CPU usage. This is the first time I've had to do anything more with AO than state levels. Am I missing something basic here?
Thanx.
