Hi, Multiple Producer loop for acquiring multiple data simultaneously
Hi,  I am trying to acquire multiple data using 3 producers loops and a single consumer loop. I have one producer lop for n-channel Analog data acquisition and 1 for a single counter signal acquision and another for a 1-channel analog voltage acquisition. When i try to run it, the program kind of errors out intermitttently , i am guessing there are some timing issues with the loop and i am not sure if i can use multiple producer loops with a single consumer loop, is ther a better way to approach this or is it just a problem withe the timing of the loop. Any help is highly appreciated.
Sakthish
(2,870 Views)
Would it be possible to show us a screenshot of your VI block diagram?
(2,864 Views)
Hi sakthish,
  Ofcourse it is possible to use multiple produceers with a single consumer,but you need to create and use three queues if you are not using events. Here in this case ,consumer is a bit complicated.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,852 Views)
You mention that you get errors but then you do not mention what the errors are. That's vital information. Since you typically cannot have an n channel acquisition and a single channel acquisition running at the same time, are you getting a resource reserved error?
(2,844 Views)
