Hi Am Getting this error can anyone help me in solving it.
Error -2147217865 occurred at NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools Select Data.vi->Connect to ACCDB Database.vi
(2,383 Views)
Look at the error message. Where is the Database table "sih1"? Did you create it successfully? Do you have a tool to inspect the database to prove, the table is there?
Greets, Dave
(2,358 Views)
Show the rest of your code.  Show your SQL query.  Show your DB table structure.
In one of those 3 places, you have the table named wrong or potentially named with an illegal name or character.
It could also be that your connection settings are wrong.  Make sure when configuring the UDL file that you are able to successfully test the connection.
aputman
(2,333 Views)
