04-20-2015 03:18 AM
Hi All, I saved a .csv file from a tektronix DPO3034 scope. I want to convert it to the .isf format that can be loaded back to the scope.
04-20-2015 03:34 AM
Hi erezg,
this is a very generic question and so you get a generic answer:
Read the scope manual to know the structure of that "ISF" format. Then create it from your CSV data file…
To be more specific:
- What have you tried so far?
- What does the manual say about this topic?
- Does Tektronix provide any tools for this?
04-20-2015 03:45 AM
Hi GerdW,
Tried to recall the waveform in the CSV format - did not work
look in the tektronix webpage and google it - still nothing
then I tried to open the isf file (binary) but seems useless.
erez
04-20-2015 03:48 AM
Hi erezg,
What are you googling for? I tried "tektronix isf file" and found this as the 2nd link result…
Again: We don't know what you have tried so far. Attach your VI and your CSV file. Also tell us what kind of waveform you expect to see…
04-20-2015 04:01 AM
saw that. did not help
I'm attaching the CSV file (look like a decaying signal). I want to load it back to the scope.
erez
04-20-2015 04:14 AM - edited 04-20-2015 04:15 AM
Hi erezg,
Why didn't it help? It explains (nearly) all the details of that format and it's all you need…
That should give you a starting point:
You can adapt all the parameters in the ISF header to your needs. (Atleast you need to change the # of points in the header according to your waveform. I also didn't care about Y scaling very much…)
04-20-2015 05:03 AM
thanks!!!!!!
ill give it a shot
looks promising...:
