Hexadecimal string to number
Hi
        I am using LV7.1. When I am converting hex  string to number , I always get  0. What could be the reason?
Madhu
Message 1 of 11
(4,624 Views)
Hi!
   Post your code, possibly just the piece of conversion...
graziano
Message 2 of 11
(4,614 Views)
Hi Madhu,
can you show us your vi or a picture of it? Maybe you use the offset output instead of value.
Mike
Message Edited by MikeS81 on 07-14-2008 01:19 PM
Message 3 of 11
(4,612 Views)
...or maybe you leave the "0x" prefix Smiley Happy
graziano
Message 4 of 11
(4,605 Views)
Hi
          here is my VI.
Message 5 of 11
(4,566 Views)
Right click on the string control and switch the display mode from "Hexadecimal" to "Normal"
Worked for me, still a little confused why it would return 0 when "Hexadecimal" is selected.  Anyone?
LabVIEW 2012
Message 6 of 11
(4,556 Views)
Hello Madhu,
turn the display mode to "Normal Display" and enter your hex code.
Hope this helps.
Uli
Message Edited by UliB on 07-15-2008 12:47 PM
Message Edited by UliB on 07-15-2008 12:48 PM
Message 7 of 11
(4,555 Views)
In hex display, it will convert but the value has to be a valid ASCII hex character (0-9,A-F). For example, if in hex display, you entered 68, that is an ASCII G and the conversion will fail. Enter in hex display an F and this is the ASCII SI character which will fail. Enter a hex 44, this is an ASCII D and you get a value of 13 out.
Message 8 of 11
(4,535 Views)
Thanks Dennis,
I thought it was ASCII however its still a little misleading.  Perhaps it really should be "ASCII hex codes" under the display properties 🙂
Craig
Message Edited by craigc on 07-15-2008 11:04 AM
LabVIEW 2012
Message 9 of 11
(4,524 Views)
If you have your heart set on using the hex display mode for the control, you have to basically add up each hex byte. Here is a VI that will do that.
The title is only a little misleading, since a normal string is character-by-character representation of ASCII values, whereas the Hex string is a byte-by-byte representation of those values.
A normal string of FF would be seen as decimals 70 and 70.
A hex string of FF would be seen as decimal 255.
Since the Hexadecimal String to Number is expecting an array of 70 and 70, a single value of 255 will throw it off. 🙂
____
Ryan R.
R&D
Message 10 of 11
(4,508 Views)
