Hexadecimal Big String to Decimal Numbers
Yes sir and my question is that i need to convert hex format string to number format  string that is given in normal format
kindly help
Message 11 of 30
(1,657 Views)
Your question still makes no sense.
Please attach a simple VI that contains a "hex format string" as diagram constant.
Message 12 of 30
(1,654 Views)
Hello Sir,
I have attached a VI showing the string that needs to be converted
Message 13 of 30
(1,650 Views)
Here's the part containing numbers. Not sure about the header, which contains non-printable characters.
Message 14 of 30
(1,644 Views)
Thank You sir this would help me Smiley Happy
Message 15 of 30
(1,637 Views)
And of course get them into a numeric array as before using "spreadsheet string to array" with comma as delimiter:
Message 16 of 30
(1,631 Views)
Accepted by topic author Anjaney
Of course if you can guarantee that the string is well-formed (i.e. 2 digits 0..F separated by single spaces, etc.), you can even do it loop-free, of course. Same result. 😄
Message 17 of 30
(1,626 Views)
Sir thanks for your taking your time and helping me i really appreciate your help and great respect to you form my side thank you sir and can you please attach its VI sir
Message 18 of 30
(1,624 Views)
Here's the last one in LV13
Message 19 of 30
(1,620 Views)
Hello Good Evening Sir,
I am facing a problem while making the reverse of the above things now i am trying to generate back the original string from numeric value please help sir
Message 20 of 30
(1,598 Views)
