Hex value to Hex display
I read in a text document from a server different HEX values ​​depending on the equipment i used. The Hex value is sent to a VI for TMT commands.
And the entrance which must be presented as HEX display.
I want to "convert" an appended path string with HEX value for example (0000 3D11 03) to HEX display (0000 3D11 03)
(2,235 Views)
Duplicate Post
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,232 Views)
