Hex string conversion problem
I need to convert a hexadecimal string (returned by VISA read) 01 to ascii string or/and to a number. Please look at the attachment. Constant has my hex string value. It is 01 in string indicator in hex display but somehow I can not convert it correctly.
BR,
Jick
(3,297 Views)
Reg
(3,282 Views)
Don's snippet should do what you want.  The problem with your VI is you were using the wrong function.
Scan from string takes a string of characters that make up a human readable number and converts them to a number.  So if your screen consisted of a "0" and a "1" (in normal display), it would have worked.  Instead you had a single byte of ASCII value 01, which is a control code in the ASCII chart and not a numeric digit.
(3,265 Views)
