Hex concatenating...
Thank you! I was completely lost in all this byte/hex talk and was just trying to piece together what seemed like the obvious solution and what I found in other forum posts. This is simple, easy to follow and most importantly IT WORKS!!!
Message 11 of 19
(766 Views)
Message 12 of 19
(747 Views)
@RavensFan wrote:
Simpler
This is the way I usually end up doing it, but I always make sure the output is correct, mostly because I'm paranoid that I will eventually find a case where it doesn't work.
Bill
CLD
(Mid-Level minion.)
Message 13 of 19
(730 Views)
Accepted by topic author plasmageek
I typically slightly complicate it by using a well named typedef (not shown) cluster and "bundle by name".
Advantage:
  1. Self-documenting
  2. You'll get coercion dots if you wire a constant with the wrong representation
  3. Defaults value can be set in the cluster, no need to wire them as constants.
  4. etc.
A typedef cluster also makes it easy to go the other way:
(NOT SHOWN: Of course you might want to do some validation, e.g. check the string length, etc. Note that "unflatten from string" would have "error" and "remaining string" outputs and is a little bit safer. Similarly, use "flatten to string". You can even set the byte order.)
Message 14 of 19
(726 Views)
Advantage:
  1. Self-documenting
  4. etc.
Well, yes.  That's really the way I do it, but the general idea was what I was in agreement with.  🙂
Bill
CLD
(Mid-Level minion.)
Message 15 of 19
(722 Views)
Advantage:
  1. Self-documenting
  4. etc.
I like to arrange my clusters like this:c.png.
To do that automatically, place the attached file in C:\ ... \LabVIEW ????\Project\.  After that, you'll be able to select the cluster and chose "Arrange Cluster Constant Nicely" from the tools menu.
Message 16 of 19
(698 Views)
@paul_cardinale wrote:
Advantage:
  1. Self-documenting
  4. etc.
I just skip all that and use the icon.  At that point, I'm more interested in what it is than what's inside it...
Bill
CLD
(Mid-Level minion.)
Message 17 of 19
(685 Views)
Hi Paul,
Thanks for this VI.
Small bug report: It mostly works, but has problems to align array constants inside the cluster:
Message 18 of 19
(655 Views)
I love this solution with the added constant to document everything.
Thanks for all the great solutions!
Message 19 of 19
(630 Views)
