Hex String to Numeric conversion
I have the following String returned by a MODBUS instrument :
My embedded data is 0104 , 7530, 7530, 7530 which is shown inside green brackets.
I want to convert them into relevant numeric data of 260, 30000, 30000, 30000.
Have been trying to do that with a  VI as attached. Not getting there right. Any help would help !!
( The attached VI is attempting to convert only the first data which is 0104)
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 1 of 26
(5,159 Views)
Here's one solution to your question.
Message 2 of 26
(5,126 Views)
Hi Raghunathan,
if you would receive your string as HEX data (as I suspect) it would be so much easier:
Message 3 of 26
(5,091 Views)
I tried the solution that you suggested... but the results were not as expected. Maybe I am doing something wrong. Need to study the code when I am more relaxed...
the code in LV12 is attached.
Raghunathan
Message 4 of 26
(5,017 Views)
Hi GerdW,
Yes if it was in Hex it could have been simple. But the feed is from a TCP read.
Raghunathan
Message 5 of 26
(5,014 Views)
It doesn't matter where the data is coming from.  All that matters is the format of the data from the read.  That information is what people have been asking for.
Message 6 of 26
(5,007 Views)
The data format is string. A point I thought to emphazise by saying its from a TCP Read - which as per LV Help is a string.
Raghunathan
Message 7 of 26
(4,998 Views)
The string is just an array of  bytes.  What is the format of the data in this byte array that shows up as a string?  I recommend you get a normal message from your instrument and save that string data to a file and post the file.  Also tell us what you expect the output to be.
Message 8 of 26
(4,993 Views)
Finally the solution.
Maybe from an expert programmer point of view, not very smart or compact code but nevertheless does the job. The project can atleast proceed.
( Possibly the Indexes can be taken as an array and a FOR loop can make the code small and compact )
Raghunathan
Message 9 of 26
(4,953 Views)
Hi Raghunathan,
yes, a VI which does the same things by copying code again and again is not very smart…
One more suggestion:
Hint: You should always get the habit of showing the string display mode, especially for your strings containing hex formatted numbers…
Message 10 of 26
(4,939 Views)
