Hex String to Float
The string you show is just the bits of a floating point single written out in ASCII. Simply use the LabVIEW "Unflatten From String" VI with single as the type. Had your data been little endian instead of big endian you would have had to invert the order of the bits.
Message 11 of 12
(1,637 Views)
Using the second part of this for converting a 32bit IEEE 754 raw interger to single precision is the best solution I have seen. No C required. Pure G and simple.
Message 12 of 12
(1,637 Views)
