Help with using an FTDI USB to SPI interface?
Hello all.
I'm just starting to try and communicate with an SPI bus pressure sensor with an FTDI USB to SPI interface. Its a UMFT220XB from Mouser and I have the data sheet etc. but wondering if there's any example code I can look at. I guess it might be as simple as writing a string and reading the result, but I'm not sure where to start with USB.
Thanks for any advice.
Andrew
(4,497 Views)
You can look at those. It might help you.
Make sure you connected the USB to SPI and installed the driver prior to open those VI. If not, LabVIEW may crash. (Windows bug)
https://lavag.org/files/file/291-mpsse-spi/
https://lavag.org/files/file/290-ftdi-libmpsse-spi/
Benoit
(4,453 Views)
Thanks Benoit. Useful links. I think the FTDI drivers also provide good functionality.
Andrew
Benoit
(4,449 Views)
Kusos are made for that... pt kudos for any answer that is useful. and select solution when it was the solution for your problem.
This is the only pay we get to help each other.
Benoit
(4,444 Views)
