Help with timing issue
Help, I am a total amateur with labview 5.1.
I need help with what I am sure is a simple problem. I am using Fieldpoint
and I need to implement a time off delay between one digital input and one
digital output. When input "a" is true i want output "a" to go true
immediately. when the input goes false I want the output to remain true for
several seconds before going false. I have tried several approaches, but I
either delay everything or nothing.
If someone could start me off in the right direction I would appreciate it.
pcarney1@bellsouth.net
(2,766 Views)
PC wrote:
> i When input "a" is true i want output "a" to go true
Dont know anything about fieldpoint but I think I can answer your question.
Drop a case structure and put the output in the True Case
In the false case drop a sequence. In the first frame add the
wait and in the second sequence add a local variable to the
output.
This will work except if it is enclosed in a while loop, then
the wait will execute everytime that the input is false and hold up the
program until the timer expires.
Hop
e this gets you going the right way.
Kevin Kent
(2,766 Views)
