Help with the MIDI read function
Yes I was hoping to be able to hear the MIDI file being outputted.  Thank you very much for your help.
Thanks again,
Joeyio
Message 11 of 13
(729 Views)
Hey Joey,
I have still not located any information on the MIDI Read control, and I am not convinced that we can play a MIDI file through it.  Today I wanted to set up an example that simply played a MIDI a file through the board, and I was succussful in doing that.  I connected a line from my audio out on my PC to the audio in on the SPEEDY, and hooked up some headphones into the audio out on the SPEEDY.  I also made sure to switch the audio input jumper from Mic to Line.
I then created a while loop that simply wired AI0 to AO0, and I was able to listen to the file playing on my computer with no problems.  Perhaps you can take this approach to analyze the signal.
Kevin H
WSN/Wireless DAQ Product Support Engineer
Message 12 of 13
(711 Views)
Message 13 of 13
(707 Views)
