Help with tcl script with labview
I am trying to run a program using tcl script via labview.
Currently I am using wish80 tcl to run it. And it works fine.
I tried using example I found on NI website called Run Tcl Script.vi
I will attach the vi and the tcl file. Hope someone will have a idea what I am doing wrong.
please change the testpairs2.txt to testpairs2.tcl as it is not letting me attach as tcl.
(4,388 Views)
Hi randyram,
try the referenced labview example with your parameters. I guess there are some changes on the OS. (actual OS with LV6.1 to XP) 🙂
LabView Online Help:
"Refer to the Calling System Exec VI in the labview\examples\comm directory for an example of using the System Exec VI."
Mike
(4,380 Views)
Thanks Mike. I just got the run tcl to work. I figure what was wrong. I calling the wrong program. I was suppose to call wish80.exe.
Once I changed that, it started to run the script. But kinda slow. I will see into why.
Thanks again.
(4,366 Views)
