Help with spreadsheet
Hallo
I want to put a header on a spreadsheet .
the problem is that the spreadsheet is in a SubVI and I want to put some values in the header, which are in VI .
I created a property node and I changed it to write, so I can wire the values in VI to the property node
but I didn't see the main code values I just saw SubVI  values.
so I was thinking if there is a way to insert a spreadsheet into an other spreadsheet or is there another simple way how to do it ?
plz see attachment to understand what i mean .
(3,077 Views)
Your description of what you're doing is unclear, and simply posting the spreadsheet doesn't clear it up. Is the spreadsheet supposed to be what you want, or what you got? Don't know why you're creating a property node to pass values to a subVI, if that's what you're trying to do. Please post your code.
(3,057 Views)
Also, seems to be a duplicate of this.
Please keep the discussion to ONE thread.
(3,053 Views)
yes exactly
I want to put the value from VI on a spreadsheet in SubVI. I 've got Info. from Dennis and Mike how to do it but if you have an e.g this will help me a lot to understand it
thanks
(3,049 Views)
