I am trying to setup a structure such that when a button is pressed (boolean True/False) that N cycles( N comes from a numeric control) of a while loop are executed and then the button is then set to false. I'm new to labview so if this is a simple question I apologize. I'm using V5.01 Thanks Jim Stockton
Jim Stockton wrote in message news:75CDD5598ED17BD7.C4CA4C14B9F7716C.E838B8882EA40A09@lp.airnews.net... > I am trying to setup a structure such that when a button is pressed > (boolean True/False) that N cycles( N comes from a numeric control) of a > while loop are executed and then the button is then set to false. I'm > new to labview so if this is a simple question I apologize. I'm using > V5.01 > Thanks > Jim Stockton
That sounds to me like a while loop with the run button and a case statement. Inside the case statement you would have the while loop that you want to run N times (or a for loop) and a false wired to a local variable of the run button.
"Jim Stockton" wrote in message news:75CDD5598ED17BD7.C4CA4C14B9F7716C.E838B8882EA40A09@lp.airnews.net... > I am trying to setup a structure such that when a button is pressed > (boolean True/False) that N cycles( N comes from a numeric control) of a > while loop are executed and then the button is then set to false. I'm > new to labview so if this is a simple question I apologize. I'm using > V5.01 > Thanks > Jim Stockton
