Help with VI
Having problems troubleshoot this VI any suggestions?
Create a new VI where temperature data, created with the Simulated Temperature
(deg F).vi in the Activity directory, is displayed on a strip chart. Compute
and display the running average of the temperature data.
Message 1 of 14
(5,003 Views)
What problems are you having?
I'm suspicious of your loop that implements the running average.   Did you look at Mean Pt by Pt?
And what is the definition of running average?  (The average of all you've ever taken?  Or the average of the last N number of samples as you progress?)
Message 2 of 14
(4,983 Views)
The running average is what Im having trouble with
Message 3 of 14
(4,975 Views)
What is your definition of running average?
What are you getting versus what are you looking for?
Until you define the problem, it is difficult to find the solution.
Message 4 of 14
(4,973 Views)
I'm looking for the average of the last N number of samples as you progress
Message 5 of 14
(4,967 Views)
Then look up Mean Point by Point.
Message 6 of 14
(4,950 Views)
Also take a step back and do a fea simple tutorials:
  • "delete from array" is not the correct function to get an array subset.
  • A "running average" is a scalar, not an array
  • Your inner FOR loop makes no sense
  • You inner while loop makes no sense
  • You need to define the loop rate. No need to spin as fast as the computer allows.
  • For a running average, you also need to define the history size.
Message 7 of 14
(4,912 Views)
Also, next time use a more specific subject. Almost all questions her are about "help with VI". You could have said "help with running average", for example.
To explore and compare many way of doing a running average, have a look at our presentation (part II) where I explore various ways of doing exactly that.
Here's how a 10 point running average could look like:
Message 8 of 14
(4,903 Views)
How do you connected the "equal to zero" to the "mean," as well as where did you find the bundled DBL and waveform blocks you used? Would you mind attaching the VI in the screen shot?
Message 9 of 14
(4,893 Views)
It is mean ptbypt, not mean. Big difference!  (find it in the signal processing... point by point...  probability&statistics palette). You already know the word "bundle", so I guess you know where to find it. I am not sure what you mean by "block", but the terminal wired to the output is just the chart. It will turn brown automatically once you connect a cluster if the right type.
Message 10 of 14
(4,874 Views)
