Help with Project regarding image import and text output
Hello all,
I am new to LabView and require any assistance you can give me. So the problem I have is that in my folder I have around 300 images that I want imported in my VI. As you can see I have two separate modules, one for green florescence and one for red. So lets say for the green, I want all the images imported and run through the module to find the area and have them output the results to a text file. This is where I am stuck. I am having trouble finding a way to import all those images in my folder and then running through the module and having them exported into a text file. Any help would be appreciated. Thank you very much.
http://imgur.com/RnfFGWq (Link that shows my module)
(2,960 Views)
Please post your diagram image here instead of linking to a site peppered with ads. Even better, attach the actual VI. Thanks.
(2,954 Views)
Here is the update
(2,939 Views)
