Help with Producer Consumer, and processing signals. (time between peaks)
Hello all,
i am working on a project and need some help.  some backround: i have worked with labview, and made some event based programs, but now have a signal processing project.  i have employed an very detailed producer consumer example, and modified it to my needs, but encountering some issues formulating a solution
i using a DAQmx to read pressure transducers that produce cyclic behavior.  i have a few goals.
1. learn best practices in labview
2. extract time between peaks (amplitude will stay the same for the same session) but will change for a new subject.
attached is the main program and processing program. Please let me know how i can solve and improve the VI's
(2,537 Views)
Hi evan,
No, you did not attach some programs. All we got are two images of parts of your code…
First step to receive substantial help on your VIs is to attach the real VIs!
(2,498 Views)
One of the glaring issues I am seeing is that the consumer should be in full control of the queue.  Your producer should sent a sentinel of some sort through the queue to tell the consumer that no more data is coming.  Then the consumer should destroy the queue when it is done.
You might also want to consider moving your consumer loops into subVIs to help organize your code a little better.
(2,495 Views)
I agree with crossrulz that you want to use Sentinels to manage the Queue in Producer/Consumer.
Here's the idea:
  • The Producer "produces" data and puts it on the Queue.  Only the Producer "knows" when to stop putting data on the Queue -- when this happens, the Producer simply exits.
  • The Consumer "consumes" the data on the Queue.  The Consumer "needs" to process all of the data on the Queue.  The Consumer should not exit until it knows that all the data that can be process has been processed.
  • The simplest way to accomplish these two aims is for the Producer, which knows no more data will be put on the Queue, to signal the Consumer by putting a special element, called the Sentinel, on the Queue.  In cases where Queue elements contain (non-empty) Arrays of data, a "natural" Sentinel is an Empty Array.  If the Queue contains a (non-empty) String, an empty String can be the Sentinel.  If the element is a Cluster and there is no obvious "unique" value to any cluster element, add a "Last Element?" Boolean.  If you take a look at the Stream Asynchronous Data Wire (which resembles a Producer/Consumer Queue), you'll notice it has a Last Element? sentinel built into its structure.
  • You have an Array as part of your cluster.  So when your Producer exits, it puts one more element, with an empty Array, on the Queue, and then finishes, leaving the Queue intact.
  • In the Consumer, as each element is dequeued, you test for Empty Array.  If False, you "consume" the data.  But if True, you simply exit the Consumer loop without processing the data.  Once you exit, you know the Producer is done with the Queue (because it sent the Sentinel), and you are done with the Queue, so the Consumer releases the Queue, knowing (a) it is empty, and (b) it will remain empty.
(2,481 Views)
Hello Gerd,
I am also a newb in asking for help 🙂
attached is the mainvi and subVI
Thanks for the heads up.
(2,477 Views)
Since I've kept this tab open for almost a week out of general interest, I guess it's time to respond.
No disagreement with prior comments.  But very generally speaking, your code is mostly a pretty reasonable approach.  Various kinds of cleanup and subvi's will help, but the essential architecture and distribution of responsibility checks out.  (Keep in mind the advice from crossrulz to let the *consumers* be in charge of releasing/destroying the queues.)
-Kevin P
(2,384 Views)
