Help with Labview for Linux application - datalog to XML format
I am working on an application that makes use of a PDA for instrument control and data acquisition, and all our code has been written with the use Labview PDA 8.2. The instrument data is returned wirelessly to a remote server, and one of the specifications we set early in the project was the data would be returned in XML format in line with Labview's inbuilt XML schema.
Unfortunately, this XML funtion is not available on Labview PDA! We have made a change to return the data in Labview's 'Datalog' format, and then we now intend to run an additional application on the server to convert this information to XML before passing the data to our customer's software.
We have successfully done this with Labview for windows, but our customer's server is Linux based.
Is anyone aware of someone (or a company) who would be able to take our existing 'datalog-to-XML' vi and compile it for Linux? The program is really simple, and I would hope that all the functionality we use is supported in Labview for Linux.
Mark
(3,719 Views)
Hi Mark
LabVIEW VIs that are developed in a Windows environment can be used in a Linux version of LabVIEW. As long as the VIs have not got Windows specific features such as ActiveX or Windows dll call you can run the VI in Linux. Also there maybe some specific drivers that are not supported under the Linux environment (see link). The VI will simply be recompiled in Linux. The Linux user must have a copy of the Linux LabVIEW Development System installed though.
http://digital.ni.com/public.nsf/websearch/35D2B5E483A001A18625716B005BE464?OpenDocument
Kindest Regards
YatinM
NIUK & Ireland
(3,691 Views)
