Help with LabVIEW Basics
Hey guys,
I'm in a hardware class and I need some help.  We use Multisim to create circuit schematics, but I mentioned to my professor that I used LabVIEW in a robotics club.  Now he wants to to write the same tutorial we used for Multisim, but for LabVIEW.  The tutorial is pretty simple, but I'm having trouble finding some components.  I need to find power supplies (mainly VCC), switches, a logic analyzer, and a word generator.  Any ideas?
Thanks.
Message 1 of 9
(5,066 Views)
LabVIEW is a programming environment, not a circuit design tool. It is not clear what you are trying to do here.
Message 2 of 9
(5,047 Views)
I am aware.  I am supposed to do something as simple as turn on an LED with a switch that is connected to a power supply.  There are waveform analyzers here for other parts of the tutorial I am writing, but I can't find certain parts.
Message 3 of 9
(5,040 Views)
Hi pareod,
You will need:
- a power supply
- a switch (relais, MOSFET, …)
- a LED
- some hardware to drive your switch
- hardware drivers for your hardware
- a LabVIEW VI that calls that hardware driver
Or do you just want to "simulate" all this? Use a button and a LED from the boolean elements palette and connect them…
As this is the very first example you will most often see for LabVIEW: take the free online courses offered by NI on their website!
Message 4 of 9
(5,034 Views)
I'm trying to simulate everything.  Is there no power supply from Controls?
Message 5 of 9
(5,027 Views)
Hi pareod,
why would you need a "power supply" in a programming language? Have you ever needed a "power supply" in C(++|#)/Pascal/BASIC/JAVA/whatever?
Do the LabVIEW beginner courses when you want to write a manual about LabVIEW…
Message 6 of 9
(5,015 Views)
The 'power supply' would just be a numeric control on the front panel and your switch could be a customized dial if you want it to look like an actual switch. Basic logic on the block diagram. Silly to look for a power supply on the functions palette.
Message 7 of 9
(4,996 Views)
Actually, I think the "power supply" can just be a boolean control here.
Oh, and here are plenty of tutorials that should show you want you want to do.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 8 of 9
(4,958 Views)
If you just need a 5V "power supply", use a numeric diagram constant with a value of 5. 😄
Message 9 of 9
(4,947 Views)
