Help with File Dialog Express VI while saving an Excel File
Hi Everyone,
Greetings !
I am making a VI to record data from a  Eurotherm Temperature Controller and saving the data into a excel file. The user needs to select the location of the file and the file name. I have been using a lot of options for this task finally I seem to be having a stable VI for it. However,  I do not understand something about this VI.
Whenever I run this VI I get two dialog boxes to select a file. One is for opening (which doesnt have any effect on the VI execution) and the other is for saving the excel.
I don't have any clue as to why I am having both these dialog boxes.
Could someone please help me understand the reason for particular behaviour and suggest ways to eliminate them.
I have attached the VI and the snapshot as well.
Looking forward to your help as always.
Kind Regards,
Jalashwa
Message 1 of 10
(6,804 Views)
Hi Jalashwa,
But you created this VI - and made all those settings in the ExpressVIs!
Check the settings for the WriteMeasurementData-ExpressVI: you did enable the file dialog explicitely…
Message 2 of 10
(6,780 Views)
Hi Jalashwa,
Attached is revised version of your VI.
I noticed a couple of things, you don't need to have 2 different calls to establish your desired file name and location. Only make this call one time when you want to save your data.
Also, if you are wanting to save all of your data, you need to use a mechanism to store that data into memory until you are ready to save it to disk. I used an append to array function with a shift register. There is also an option in the attached VI to save all of your data or just the last acquired waveform.
Hope this helps.
Mike
Certified LabVIEW Architect
Miami University
Instrumentation Laboratory
CLA Logo
Message 3 of 10
(6,737 Views)
@thinkGerdW wrote:
Hi Jalashwa,
 Think "Dataflow"
And, those settings conflict.  What where you thinking? "Run as fast as possible" , a 100mSec duration and a 1000 mSec wait in the outer loop?  That won't work even after you provide some data dependency between the two express vis
Hold it! the first express vi REQUIRES you to select a new file.  what does the next one do if the file exists?  It wouldn't want you to "Rename the existing File" would it?
Spoiler
Yup, oh snap! it does!
So, are you laughing yet?  - Or is this more of a "Next-day funny" moment?
"Should be" isn't "Is" -Jay
Message 4 of 10
(6,711 Views)
Hi Mike,
Thanks for your help.
However, I could not open the VI as I run LabVIEW 13 and your VI was made in LabVIEW 16.
Could you resend the VI for LV 13 please
BR,
Jalashwa
Message 5 of 10
(6,690 Views)
Hi Gerd,
I use LabVIEW which is in German, a language am not very proficient in so I miss out on somethings
I did try some of the setting but did not achieve what I wanted.
Thanks a lot for your help 🙂
Message 6 of 10
(6,687 Views)
Hi Jalashwa,
well, I also use the German LabVIEW version… 😄
(You will find the English LabVIEW help on NI's website so you could read the help in two languages! ;))
This is (a part of) the config dialog for WriteMeasurementData ExpressVI:
The red marked boolean input dis-/enables the file dialog of the WriteMeasurement-ExpressVI. You enabled the file dialog - and then wondered about the second file dialog…
Message 7 of 10
(6,685 Views)
Accepted by topic author Jalashwa
Hi Jalashwa,
You're welcome, glad to help.
Please see the attached file, saved in LV2013 (let me know if you are unable to open it).
Thanks.
Mike
Miami University
CLA Logo
Message 8 of 10
(6,680 Views)
Thanks a lot Mike
Message 9 of 10
(6,678 Views)
Hi Jalashwa,
You're welcome, glad that we were able to help you.
Thanks.
Mike
Miami University
CLA Logo
Message 10 of 10
(6,674 Views)
