That's a good suggestion Paul! Personally, I use an RS232 cable that I have
chopped in half, and then reconnected using a screw terminal block (also
available from Tandy, if you like!) - use a continuity tester (most multimeters
have them built in) to find out which wires refer to which pins. Have a look
in the Hardware Book (http://people.aero.und.edu/~nordlie/hwb/menu_Connector.html)
for more info on what to connect to where.
cheers,
Christopher
"Paul Conroy"
wrote:
>ahhhhhhhhh! the dreaded RS 232 interfacing problem. Just a suggestion,
(as>it might not be this), make sure that you have the right pins configuration.>Often,
for example, a 9 pin in serial communication needs to have pins 2 and>3 reversed
in the lead so that
on both instrument and com port, pin2 is TX>and pin3
is RX. A pre-constructed lead from Tandy etc usually doesn't.>>Other issues
could be related to the operating system.>>Happy RS232ing!>Regards>Paul Conroy>>ye1122
wrote in message <0ceccf32.b4a9ad19@usw-ex0105-035.remarq.com>...>>I can
write to RS232 port in labview, but I couldn't read the>>responce from instrument
on RS232 when i was using the serial>>port VIs or visa VI's. What I read
from RS232 was the last>>command I sent to it. If I tried to use any terminal
program,>>communication was very well. I wonder why. Could someone give me>>some
sugguestion? Thanks in advance.>>>>Tong>>>>* Sent from RemarQ http://www.remarq.com
The Internet's Discussion Network>*>>The fastest and easiest way to search
and participate in Usenet - Free!>>>>
