Help: what to install?
Hi, I have the following (new) hardware: Ni-cDAQ 9172 and NI-9213.
In order to make them work I downloaded:
1) the last labview 2009 software from NI site.
2) Then I downloaded the last NI-DAQmx 9.0.2
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288290
My question is if I need also the NI Device Drivers 2009.11 (https://www.ni.com/en/support/downloads/drivers/download.ni-device-drivers.html#327622)
or maybe the NI-DAQmx 9.0.2 is enough?
In the case that the NI Device Drivers are necessary, have I to install before or after the NI-DAQmx?
Thanks in advance
(2,668 Views)
You will only need DAQmx, which is btw also part of the Device Drivers DVD.
Christian
(2,658 Views)
