Help: use ELVIS II+ generate PWM
HI, i an new to LabVIEW and i want to use ELVIS II+ generate PWM signal in vi. the signal should be 20 K Hz, 0-5 V. and i want to control its duty cycle.
thanks for help.
(3,032 Views)
Cooper,
From the ELVIS II User Manual:
"For square wave mode, a triangle wave from the DDS is fed into a
comparator. By adjusting the reference voltage of the comparator, you can
control the duty cycle. The reference voltage is generated by a 10-bit DAC
circuit. You can adjust the square waveform output duty cycle in software
with the NI ELVISmx FGEN SFP."
Ian K.
Software Developer
Data Ahead AG
(2,992 Views)
Thanks for help. Now I find a easy way to do it. I use signal simulator to create PWM and send scaled square wave to DAQ Assistant block. At last, I use Analog output to output PWM from ELVIS.
Thank you.
(2,975 Views)
(2,974 Views)
